guido4725 Posted April 8, 2014 Share Posted April 8, 2014 Hi iv got a 94 mk3.5 fiesta 1.3 hcs, and I was just wondering if I could swap the engine for a xr2i 1.6 8v an if it was possible what would I need to do...any help would be much appreciated. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
FOCA Posted April 12, 2014 Share Posted April 12, 2014 in General, You would need all the xr2 engine parts, including inlet/ exhaust, peripherals /engine electrics, the xr2 probably has a different gearbox, with a different final drive or close ratios etc, the front brakes may be bigger, the suspension may be different, often with thicker anti-roll bars With the xr2 ECU, you may need the matching ignition barrel, key and locks (from the xr2) Anything is possible - FWD fiesta to FWD fiesta should not be too much of a problem - often, it is cheaper/ easier/ better to just buy an xr2, unless you have an xr2 engine kicking about, or a smashed xr2 Shell or are building a race car/ have some sort of special reason etc etc Quote Link to comment Share on other sites More sharing options...
