AdBlock Warning
KaLiz
Engine Light - Help!
5 posts in this topic
Bought streetka 06. Light comes on. Coil pack replaced. Drive away light comes on again and losing power. This time injector replaced. Drive away light comes on again. Any ideas?
lambada sensor ? if you can get a code i maybe able to tell you what it is.
I had all sorts of problems with the injectors and sensors on my wifes old StreetKA. A bottle of Cataclean and an Italian tune up used to clear it. Just give it a good thrashing as I found that whenever the car had been left for a while the injectors and the sensors must have furred up. It always played up when we had been away on holiday.
Delboy what is this sensor and how do I find the code? Should the garage be able to do this?
the sensor plays up sometimes. it mixes the air and fuel & if it goes wrong it will thor the engine management light on
here is a piccy of it
https://www.google.co.uk/search?q=lambda+sensor+ford+ka&client=firefox-a&hs=XtT&rls=org.mozilla:en-US:official&channel=sb&source=lnms&tbm=isch&sa=X&ei=6CtGU8jxLsjnOq_tgJAI&ved=0CAkQ_AUoAg&biw=1680&bih=878#facrc=_&imgdii=_&imgrc=OTHawNo39w_PyM%253A%3BJ4fTz41kbcMV7M%3Bhttp%253A%252F%252Fwww.veedoubleu.com%252Fwp-content%252Fuploads%252F2012%252F02%252F001_lambda_sensor_top.jpg%3Bhttp%253A%252F%252Fwww.veedoubleu.com%252Fnon-vw%252Fford-ka%252Flamba-sensor%252F%3B512%3B384
or maybe located here
https://www.google.co.uk/search?q=streetka&client=firefox-a&hs=Eqo&rls=org.mozilla:en-US:official&channel=sb&source=lnms&tbm=isch&sa=X&ei=HjBGU6TKGorsOci5gJgK&ved=0CAgQ_AUoAQ&biw=1680&bih=878#channel=sb&q=streetka+lambada+sensor&rls=org.mozilla:en-US:official&tbm=isch&facrc=_&imgdii=_&imgrc=fhoXcqrwk0VR3M%253A%3BLniMGE-9e1SXiM%3Bhttp%253A%252F%252Fwww.fk-oc.com%252Fe107_files%252Fpublic%252F1264951256_142_FT19055_lambda_sensor.jpg%3Bhttp%253A%252F%252Fwww.fk-oc.com%252Fe107_plugins%252Fforum%252Fforum_viewtopic.php%253F19055%3B480%3B640
it's a 22mm open sided socket needed to remove it. maybe best to ask a garage to do that
you can take car to small local garage for a check and ask them to turn the management light off as it stays on sometimes even if the fault has been sorted as your one maye have been a glitch & is fine.
look here for the obd to buy. brilliant tool to have
http://www.ebay.co.uk/itm/111295005462?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
this is what i got it comes with a book with all the codes it generates cheapr than paying a garage to do it if they charge as it can be £50.. +
