ben1191
Boot Opening By Itself
3 posts in this topic
Done some research and seen that it was subject to a recall,would mine still apply or is that only when they're under warranty.driving along and all you hear is click click click of it opening itself...
I had a similar problem with mine. Turned out to be water in the latch/handle. Removed it, cleaned water and crudd out, sprayed it with Silicon grease and reassembled. About a 30 minute job IIRC ;-)
Already onto that mate,filled with water.given it a good clean but the metal bracket thing inside has lost its little rivet bits that hold it into the plastic so I'm sitting here with some silicone behind It waitin for it to dry :D
