Stu9 Posted April 16, 2014 Share Posted April 16, 2014 There's a place a few miles from me does it (fits them) but you can buy the same things online, so will see how hard it is to do. I put H7R's in but not happy with them (03 focus) so this is the next best thing apart from ST170 xenons Seemingly this is the right way to fit xenons to headlights that are originally for halogen.....has anyone did this, the bi setup, not the ST lamps...just wondered Quote Link to comment Share on other sites More sharing options...
Chris_pickford94 Posted April 16, 2014 Share Posted April 16, 2014 Bi xenons fit exactly the same as regular hid Kits, just a piece in the bulb assembly moves when you'll switch between high/low beam They are however illegal, this is because they would be fitted in a reflector type housing and not in a projector style headlight like they are designed for Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Stu9 Posted April 16, 2014 Author Share Posted April 16, 2014 That's right, I had one in the bike last year, he said (headlight retrofit) they're housed in a projector case which makes them seemingly legal.... well that's the impression I got I've still the 2 bi xenons in the basement but they're h4 not 7 so can't try them, but like I say, he says he puts them in housing first not straight in the lamp Quote Link to comment Share on other sites More sharing options...
k13r4n Posted April 18, 2014 Share Posted April 18, 2014 If the light is fitted into a projector lense that is xenon compatible then it will pass an mot. The test requires that cars fitted with xenon out of the factory require auto levelling and washers. The test also says that cars fitted with halogen bulbs must produce the correct beam pattern and comply with correct colour temperature so therefor not stipulating on the bulb type. Dangersford had this mod done to his fiesta. Sent from my HTC One using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Jeff4155 Posted April 23, 2014 Share Posted April 23, 2014 I do have the Halogen Projector Lights, so is it possible for me to retrofit Xenon lights? the lights are alot brighter than the standard once, but I had Xenons on my golf 5 and it was like daylight, would like to have that with the fiesta as well Quote Link to comment Share on other sites More sharing options...
