ianc65 Posted April 20, 2014 Share Posted April 20, 2014 Hi all, my 2008 Focus estate (1.8L TDCi) has developed a nasty thudding sound when I turn the wheel to the right. These thuds are timed to the road wheel speed so the faster I go the more frequent it becomes - took it on long run after all repairs below and worse than ever, the wheel only has to move slightly from dead straight and thudding begins big style a bit concerning when on motorway! I have replaced the drop-links, had the wheel alignment checked and adjusted, had all wheels balanced, replaced front drivers tyre which was worn unevenly - all with no success. I have read threads which suggest CV joints but there is no sign of any damage to outer or inner rubbers and no leakage of grease so I'm confused. Do CV joints wear out, get damaged by pot holes? Car has done 90K Any advice Ian Quote Link to comment Share on other sites More sharing options...
Stu9 Posted April 20, 2014 Share Posted April 20, 2014 A cv usually clicks and on full lock, unless it's that bad that's what it is Quote Link to comment Share on other sites More sharing options...
Jeff4155 Posted April 20, 2014 Share Posted April 20, 2014 That does sound like CV joints and yes they do wear out, sometimes its just the boots, other times it might just be the full link, I replaced mine twice over 240k km on my old Toyota conquest, good luck Quote Link to comment Share on other sites More sharing options...
ianc65 Posted April 29, 2014 Author Share Posted April 29, 2014 buying two compete drive shafts (left & right). Will have a go at replacing drivers side first as the sound appears to be louder on that side. Fingers crossed Quote Link to comment Share on other sites More sharing options...
ianc65 Posted May 23, 2014 Author Share Posted May 23, 2014 Ok I changed both drive shafts and no improvement - noise still occurs when turning wheel to right and is louder if more weight on front left (down hill turn to right). I did notice that the near side drive shaft spines which fit into the wheel bearing had a rusty deposit. I have swapped all tyres around and the noise is still the same. Taken to garage and had thorough inspection but no obvious wear in any joints or suspension and no indication of wheel bearing failure. I have made a short video of the noise which can be found at https://www.youtube.com/watch?v=sU0Z7Y6-EQk. Any more ideas as to the cause - I am thinking of replacing the near side wheel bearing next but if anyone has any other advice I would be happy to hear. Quote Link to comment Share on other sites More sharing options...
ianc65 Posted September 9, 2016 Author Share Posted September 9, 2016 I did go ahead and got the front nearside wheel bearing changed and noise has now completely gone. So 'thudding sound' was a wheel bearing starting to go. 1 Quote Link to comment Share on other sites More sharing options...
