choppah666 Posted April 23, 2014 Share Posted April 23, 2014 hi all I'm changing the engine in my van as i hydro-locked the old one the new engine has come with the ecu, clocks and two keys. will my ignition barrel be coded to my previous ecu? thanks in advance Dan Quote Link to comment Share on other sites More sharing options...
mick85 Posted April 23, 2014 Share Posted April 23, 2014 Why u have new ecu an clocks is it different type engine Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
choppah666 Posted April 23, 2014 Author Share Posted April 23, 2014 No same type engine. Injectors were damaged and I was told the were definitely coded. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
mick85 Posted April 23, 2014 Share Posted April 23, 2014 I would just take numbers Down off injectors an put new engine in an drive it most likely they be fine if worst comes worst u could get recoded cheap enough Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
choppah666 Posted April 23, 2014 Author Share Posted April 23, 2014 Oh really. Okies. Thanks for your help Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
