sonic113
Best Spark Plugs For Focus 2009 1.6 Zetec
just wondering what spark plugs you guys use and what is the best to put in the 2009 focus mk2.5 1.6 zetec engine?
thanks
I'd love to know this also, at the moment i've got Champion Spark Plugs.... i cant remember the model name of them though.
bosch or ngk are what ford fit as standard gapped at 1.0mm i use the Bosch as thats what came in thew car from the factory some use the ngk personally i wouldnt use any others
so whats the best spark plug for the 2009 mk2.5 1.6 zetec focus?
if you guys have any plug numbers that would be great.
also what gap is best to set plugs at is it 1.0mm?
thanks artscot i will see what plugs my local auto shop have and use them with a 1.0mm gap.
what make/model of plug do you use?
I used some ngk iridiums, bit more pricey than regular plugs, but worth every penny.
I went from using ford motorcraft plugs at £3 a pop to these ngk iridiums at a tenner each and the engine feels much more zippy.
Well worth it if you want to upgrade
+1
Ive fitted the NGK Iridium IX to my 1.6 petrol toyota and found a noticable difference in throttle response,
So they are bound to be better on the more modern focus zetec engine which uses coil pack ignition,
Guranteed better spark resulting in cleaner burn and more economical,
Id purchase from ebay.co.uk tough as there much cheaper than the shops for these spark plugs.
Heres a link to the ones you require: http://m.ebay.co.uk/itm/120841973313?nav=SEARCH
Your motor takes: NGK Spark Plugs Iridium IX LTR5IX-11
thanks Lenny for the link,
so would these be the best ones to use in my zetec engine? and roughly how long will they last before needing replaced?
thanks
