Focus Mk 2 Towbar Wiring Help
7 replies to this topic
#1 the mad triker
the mad triker
    Member
  • Budding Enthusiast
  • PipPip
  • 10 posts
  • Name: craig
  • Ford Model: focus mk 2 tdci ghia estate
  • Year: 2007
Posted 25 April 2014 - 06:09 PM
hello im new to this forum i recently installed a towbar on my mk 2 focus but do i need a bypass relay or not.
any comments would be a big help :huh:
Have something to contribute?
#2 dezwez
dezwez
    Dezwez
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 5,064 posts
  • Name: Derek
  • Ford Model: ford focus 1.8 zetec mk 2.5
Posted 25 April 2014 - 06:47 PM
yes its cambus wiring
#3 the mad triker
the mad triker
    Member
  • PipPip
  • 10 posts
  • Name: craig
  • Year: 2007
Posted 25 April 2014 - 08:52 PM
ok many thanks will get the relay :rolleyes: :rolleyes:
#4 theduke
theduke
    Hairy Member
  • 356 posts
  • Name: James
  • Ford Model: Focus Mk 2.5 Zetec
  • Year: 2009
wired mine in without bypass relay it all works fine :)
You will need the indicator bleeper tho for mot apparently
#5 JW1982
JW1982
  • 788 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 26 April 2014 - 06:07 AM
You will need the reverse bleeper tho for mot apparently
You should be very careful with that.
On the Focus MK2/MK2.5 there is a high risk of damaging the GEM module/fuse box. On these cars all light functions are controlled by the GEM module/fuse box. The GEM module/fuse box is not designed to handle the extra current of the trailer lights. The extra current may damage the circuit board of the GEM module or in worst case even set the car on fire.
A new GEM module/fuse box will cost a lot more money than a bypass relay or a vehicle specific cable kit.
#6 theduke
theduke
    Hairy Member
  • 356 posts
  • Name: James
  • Year: 2009
Posted 26 April 2014 - 07:11 AM
Stand corrected! Been towing my shabby old caravan for nearly a year with no ill effects though, thought the relay was for bulb out errors only Thanks!
Sent from my GT-S6810P using Ford OC mobile app
#7 dezwez
dezwez
    Dezwez
  • PipPipPipPipPip
  • 5,064 posts
  • Name: Derek
Posted 26 April 2014 - 08:42 AM
I used one of these
http://www.ebay.co.u...=item2eb9d5b1bd
#8 leofynn
leofynn
    Member
  • PipPip
  • 10 posts
  • Name: Adam
  • Ford Model: Focus 1.6 tdci zetec
Posted 01 July 2014 - 08:31 PM
Hi this is my first post. i have a 2010 focus. Ihave fitted a flange towbar and have ran my cable from the battery to the boot and located the plug in wires. now i have the problem of knowing which colour is going to which bulb? i have a single electrics with a bypass relay. hope this makes sense. any help appreciated :)
Not what you're looking for?
