SuperTed
Engine Fault Codes P0607 And P2110
Engine Systems Fault message appeared on dash then showed Low Speed Mode. Massively reduced power and engine sputters. Garage read codes p2110 and p0607.
P0607 is where a malfunction is detected in Engine Control Module.
P2110 is Throttle actuator control system forced limited rpm.
Advice would be greatly appreciated. What is worth checking before going down the route of replacing expensive replacement parts which may not be the root cause? If the ECU and/or throttle body are going to be replaced in an attempt to resolve, which is best to try first?
Have u access to any diagnostic equipment I would start with second fault check accelerator pedal and throttle and wiring if they all good most likely internal fault in PCM
