Supersons
Bluetooth Connectivity With Sony Cd6000 - Ford Focus (98)
I have upgraded my phone to a Samsung Galaxy S4 from a Samsung Galaxy S2. However I cannot connect my phone to my Sony CD6000 Radio. Code does not appear when I try to pair. I have tried looking at the compatibility list on the ford site but the link does not work. Any suggestions would be gratefully received
Thanks Martin
Sorry, It was a bit obvious. Are any other phones bonded to it ?, if so debond them all and try again.
I'am not saying that it will fix the problem but its something else to try.
I believe that only a total of 6 phnes can be bonded to the BT module at any time so deleting old ones is definitely a good start.
It may be worth doing a BT module reset by pulling the plug out of the module and leaving for 10 minutes.
Which year is your Focus and which type of radio is installed? The 6000CD and Sony are 2 different radio's. The 6000CD is the standard Ford radio which is made by Visteon and has nothing to do with Sony. The Sony is the Original premium radio which was available in single CD or 6-CD changer version with or without DAB. The Sony is also made by Visteon but is licensed by Sony.
Focus MK2 and early MK2.5 versions (until approximately 04-2008) do have the old bluetooth/Voicecontrol system which uses bluetooth/Voicecontrol modules which can not be updated. My experience is that many newer phones are not supported and do not function correctly with the old system.
Later Focus MK2.5 versions (after approximately 04-2008) do have the new bluetooth/Voicecontrol system. Modules of this system can be updated to support newer phones. Modules which do not support USB playback (part number 8M5T-19G488-XX) do have a USB connector for update purposes. These modules can only be updated by Ford. Modules which support USB and bluetooth Audio (A2DP) playback (part number 8M5T-19C112-XX can be updated by performing the Ford Audio Update which can be downloaded from the Ford website.
If your car has the old bluetooth/Voicecontrol system and your Phone is not supported it probably will never work.
If your car has the new bluetooth/Voicecontrol system the problem may be solved by updating the bluetooth/Voicecontrol module firmware.
Hi i have got the same problam i have updated my cd player to the sony and now cant get my phone to link up to it. Before i instaled the sony cd player my phone was linked up to my old cd player any clues on what i need to do cheers
You possibly might have the wrong type of Sony radio.
In fact there are 2 types of Sony radio. The 2nd Generation Sony and the 3rd Generation Sony. These radio's look identical but are technically different.
The 2nd Generation Sony was originally installed into the late Focus MK2 (produced after 26-03-2007) and early Focus MK2.5 (produced before 10-04-2008). This type of radio is designed for the old bluetooth/Voicecontrol system and combined with the bluetooth/Voicecontrol system only supports Phone functionality.
The 3rd Generation Sony was Originally installed into the Focus MK2.5 (produced after 10-04-2008). This type of radio is designed for the new bluetooth/Voicecontrol system and combined with the bluetooth/Voicecontrol system supports Phone functionality and (depending on the type of module) also USB, bluetooth Audio and Ipod control.
Radio's and bluetooth/Voicecontrol modules of the old and new bluetooth/Voicecontrol system are not compatible. If your car is modelyear 2009 it has the new bluetooth/Voicecontrol system. So your Sony radio needs to be a 3rd generation Sony. If you have a 2nd Generation Sony installed the bluetooth/Voicecontrol functions do not work correctly or do not work at all.
Whether your radio is a 2nd or 3rd Generation Sony can only be determined by the production date of the radio and the part number of the radio.
Part number 7M5T-18C939-JE is a 2nd Generation Sony radio. This part number is produced between 26-03-2007 and 15-01-2008. If your car is a 2009 model this is not the correct type of radio for your car.
Many people make this mistake.
Hi mate sorry to bother you agen but can you tell me if this is a 3rd gen please post-57087-140768581584_thumb.jpg
Part number 7M5T-18C939-KE is also a 2nd Generation Sony. This part number is also produced from 26-03-2007 to 15-01-2008.
There is a sticker on top of the Sony radio's listing the production date. For a 3rd Generation radio the production date must be 04-2008 or later. The very early 3rd Generation Sony radio's did have a firmware version which does not support USB. If you want to retrofit the USB connection also you should look for a Sony with a production date of 07-2008 or later.
Edited
Posted in wrong thread
Sent from my GT-I9505 using Ford OC mobile app
