Vick117
Ford Fiesta Cat Converter Problem
9 posts in this topic
Hi, I'm new to this forum. I own a 2002 ford fiesta zetec 1.2 16v. I took on the car from my grandad and a few months of having it the engine light was staying on. I took it to a garage and they said my CAT converter is blocked and needs replacing. This was replaced in August 2012. Come June the next year my car is making an awful noise, blowing very loudly me thinking I have a whole in the exhaust. A family member told me the noise was from the CAT converter, the flexi pipe had blown. The part was only 10 months old. I had it replaced as it was under warranty with no cost to me. The same thing has happened this month. Exactly 10 months I have had the new CAT converter and my car is making the same noise. The flexi pipe mesh is crumbling under neath the car.
I was originally told that that CAT converter was a dud, it was faulty that's why it had blown. So not expecting it to happen as second time, the part certainly lacks quality or something. after 10 months a CAT converter should not be going.
Has anyone had a similar problem, can it be something else that is causing the CAT converter, specifically the flexi-pipe, mesh to come away and crumble?
Any responses will be greatly appreciated.
Vick
Hello and welcome.
Don't worry about the mesh, that will eventually bursts and come away. It's the concertina like bit within the mesh that matters.
Do you know what make the cat is? Sounds like it's either under some kind of stress, possible from a worn engine/gearbox mount or it's just cheap rubbish I'm afraid
Hi and welcome take it back and tell them you want it sorting out
Hello,
Thanks for your quick response.
I'm not sure what the make of the CAT is. I took my car to a vauxhall garage as it was recommended to me, as they also fix other cars besides vauxhall. They got the part from a Ford dealer. The part cost £147.
Vick
Clearly somewere there is a problem i would take it back tell them its gone again then wait and see what responses you get on here or go to another garage after its done and see what they suggest
They have said again that they will replace it again at no cost to me but once we reach June, it's been 2 years since the original replacement, then there is no warranty left then it's my problem basically. Even though it would have been a new part as from this April.
Are you sure each part is not warrented for 2yrs ?? Get them to fit new 1 on and then go to other garages for answers pref a ford garage
Once it's fitted I would have them check out the engine/gearbox mounts and have a look at the rest of the exhaust system to see if there is a reason for the constant failures
Moving to the fiesta forum
