Hellboy Posted May 1, 2014 Share Posted May 1, 2014 On my 2001 1.6 Ghia where is the breather pipe? Does anyone have a picture? Cheers Quote Link to comment Share on other sites More sharing options...
FOCA Posted May 1, 2014 Share Posted May 1, 2014 On my 2001 1.6 Ghia where is the breather pipe? Does anyone have a picture? Cheers You can't miss it, it comes out of the rocker cover and into the inlet - if you post a picture of your engine bay up i could probably point it out ! Quote Link to comment Share on other sites More sharing options...
Hellboy Posted May 1, 2014 Author Share Posted May 1, 2014 Not mine but same engine Quote Link to comment Share on other sites More sharing options...
FOCA Posted May 1, 2014 Share Posted May 1, 2014 Thats the one Quote Link to comment Share on other sites More sharing options...
Hellboy Posted May 1, 2014 Author Share Posted May 1, 2014 Is it a fiddle to get off. I am guessing the top one I just pull. What about where it disappears to? Quote Link to comment Share on other sites More sharing options...
FOCA Posted May 1, 2014 Share Posted May 1, 2014 Is it a fiddle to get off. I am guessing the top one I just pull. What about where it disappears to? What are you actually planning to do? Quote Link to comment Share on other sites More sharing options...
Hellboy Posted May 1, 2014 Author Share Posted May 1, 2014 I have the idle hunting issue. Tried a new could a ht leads. Quote Link to comment Share on other sites More sharing options...
Hellboy Posted May 1, 2014 Author Share Posted May 1, 2014 I meant coil pack. So is it easy to check for splits and such? Quote Link to comment Share on other sites More sharing options...
Hellboy Posted May 2, 2014 Author Share Posted May 2, 2014 Anyone? Quote Link to comment Share on other sites More sharing options...
FOCA Posted May 4, 2014 Share Posted May 4, 2014 I meant coil pack. So is it easy to check for splits and such? Its diffucult to check as a damaged coil pack could look ok - best to start with the spark plugs (cheaper, and may fix the problem) slightly narrow the gap can help "prop up" dodgy coil packs You would be wise to invest in a clde reader/ get the codes read before spending money you dont need to (plugs are a consumable, anyway) Quote Link to comment Share on other sites More sharing options...
