Chris_carbon
Still Not Fixed!!!!!!!!!!!!
5 posts in this topic
Had usual injector problem
Got new set
Programmed earlier today (communication problem to start with but after an update all is well)
Running fine from 2 ish till about 6
Go to start car again around half seven , won't start , after 5 mins it fires up , drives ok till I push it a little and then it drops power an glow light flashes
Turn off turn on , light out all good , 2 minutes later light back on then 50yds later cuts out and won't restart , 2 mins passes and it fires up
This time EML on Aswell
Creep back to base
Proceed to shout profanities at sky as if it would help
I'm confused , anybody got any ideas ?
Thanks folks
Chris
Sent from the enterprise
Hi Chris,
Sounds like the timing isnt right?
I too have thought this , it's been checked and given the all clear ,
Apparently the "new" injectors were as weak as anything and weren't holding pressure , originals now need reconditioning .....
This I turning out not to be so much fun to own as I thought :D
sadly this is the common issue with this model mondeo! its a pain in the backside at best!
Aye true , but they are now being sorted and hopefully I will have a working car by weekend , only things left to do are sort the heko deflectors and MOT the !Removed! thing , hopefully it will be worthy of some pics for the build thread page soon
