iant955
Problems With Led Trailer Lights.
1 post in this topic
Hi Guys,
I have an 09 SMax and have recently restored a box trailer and fitted it with LED lights.
When I indicate, the indicators flash too quickly indicating a fault with the indicators.
I believe this is due to the low draw of the LED indicators and a fault common on some Fords and Landys.
I have seen some options which should fix the problem, but nobody seems to know anything about them.
I am looking to mount a cure inside the trailer, but the one I have come across most (a basic resistor) gets to 170 degrees C. I ave also come across some other options, but wouldlike some more info on them.
Smartbox | LED Lighting | Lights, Reflectors & Electrical | Trailer Parts | Indespension
http://www.ledautolamps-uk.com/en/products/i-ls-microprocessor
Has anyone had the same problem and if so, how did you get over it?
Thanks in advance.
Ian
