Jaynie91 Posted May 10, 2014 Share Posted May 10, 2014 My friend has got a Ford KA, 2003, which the engine management light is on and the car is juddering as soon as the engine is turned on. They have changed the spark plugs and coil pack as per recommendation from a garage however it still has the problem. The HT leads haven't been changed however they are still sparking. Has anyone else had this problem? Thanks Jayne 1 Quote Link to comment Share on other sites More sharing options...
delboy Posted May 10, 2014 Share Posted May 10, 2014 go buy yourself a diagnostics tool for about £20 from eBay and it will show you the codes http://www.ebay.co.uk/itm/Universal-CAR-OBD2-EOBD-CAN-Fault-Code-Reader-Scanner-diagnostic-scan-tool-/331166274325 Quote Link to comment Share on other sites More sharing options...
delboy Posted May 17, 2014 Share Posted May 17, 2014 did you manage to fix the problem and how ? 1 Quote Link to comment Share on other sites More sharing options...
DELRIO Posted August 11, 2014 Share Posted August 11, 2014 My streetka 2004 has just started doing exactly this today! Did u get it sorted jaynie??? Quote Link to comment Share on other sites More sharing options...
DELRIO Posted August 11, 2014 Share Posted August 11, 2014 Just had it on the diagnostic and its a 'cylinder 2 misfire' so just need to source the cause of the misfire. Any input greatly appreciated! Quote Link to comment Share on other sites More sharing options...
stephenaxon Posted October 9, 2014 Share Posted October 9, 2014 My car has started doing this on aswell any info?would be handy Quote Link to comment Share on other sites More sharing options...
DELRIO Posted October 20, 2014 Share Posted October 20, 2014 i ended up getting the spark plugs, leads and coil pack replaced. it sorted the problem ... for a couple of months and its just started playing up again :/ could be due to the fact that i bought cheap aftermarket parts rather than genuine ford ones? ford want £100 just for a set of leads whereas the non-genuine ones were only £25. think im gona try find a set of genuine ones on eBay before i splash out £100 just incase its not actually the leads causing the problem. input from anyone greatly appreciated :) Quote Link to comment Share on other sites More sharing options...
DELRIO Posted November 1, 2014 Share Posted November 1, 2014 replaced the coil pack and leads again and it made no difference. stuck a bottle of redex valve cleaner in the fuel tank and boom she seems to be back to her old self! Quote Link to comment Share on other sites More sharing options...
