AdBlock Warning
gary12345
Speedo / Fuel Gauge Fault
5 posts in this topic
please help,
I have a galxay 1.9tdi 2001 with 118000 miles the car has devoloped a fault which i'm sure most have seen but i can't find anyone that has found the cure.
here goes: The speedo has stopped working and when you start driving the fuel gauage goes up and down.
things that i have done are: replaced the speedo with a 03 model which works fine but runs MPH to fast, so i bought another second hand one which came off another 2001 model and have the problem, so i'm gussesing that my clocks are fine. i have checked the wiring that goes in to the clocks and they are all free from corresion, also done a wiggle test on them.
As the 03 clocks work i know its not a fault with the speedo sensor or fuel sensor as work fine with those clocks it just reads wrong MPH e.g when i do 70 it shows 110mph
Has anyone else had this problem or know how to fix, driving me up the wall now
Many thanks in advance
Hi Gary, I had a problem like that a few years back n if my memory serves me correct it can possibly be faulty brake light swith or maybe something as simple as a fuse/relay. Hope it helps ;-) I'm actually having fun with my electrics. Fuse box is sending me morse code and my interior lights are like a disco. Hoping it only a relay :-D
I had a similar fault on my V6 but maybe the same system.
I had done work on my engine and I forgot to put the speedo sensor back onto the gearbox!
So it could be your speedo sensor that is at fault.
im assuming you managed to get this sorted out?
