gary12345 Posted May 14, 2014 Share Posted May 14, 2014 Evening all I have a ford galaxy 1.9tdi on a 2001 The speedo has stopped working and the fuel gauge goes up and down when driving. Fuel gauge show correct when still For them both to go at the same time I'm looking at a wiring fault I have read forums with people with the same problem but can't find anything that has fixed the fault Things that I have done is changed the speedo from a 03 model and the speedo and fuel gauge works fine apart from speedo does not give a true reading as I believe they change the cluster on this year. So I bought another from the same year (2001)and that does the same. Fuel gauge goes up and down and speedo not working. I know the fuel gauge and speedo are not at fault. I have also disconnected the battery for 24hrs. There is no corrosion on the wiring on the 2 blocks that plug into the speedo. Can't under stand how the 03 model speedo works but the earlier model does not Can anyone shed some light on what the fault could be. Many thanks in advance Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
