tractorboi711 Posted May 17, 2014 Share Posted May 17, 2014 So I connected the remote wire from my amp to the audio fuse but the amp turns on even when the radio is not turned on and neither is the ignition. I also tried to put the wire in the fuse for the ignition but it did the same thing . How can I get it to turn on only when the radio does? don't really want to have to take the facia off again as it was a pig to put back! Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 17, 2014 Share Posted May 17, 2014 Sounds like you wired it to the permenant live feed. The radio has two feeds - ignition on - turns the radio on with the ignition, secondly it has a permenant live feed, this si what feeds the one hour mode when you turn the radio on with the keys out. Quote Link to comment Share on other sites More sharing options...
tomtom70 Posted May 17, 2014 Share Posted May 17, 2014 You need an output that's switched with the headunit - which would be called remote or SW(itched) A(ntenna) on the Ford OEM unit. The there is always voltage on the audio fuse even when the headunit if off is pretty obvious (else the headunit could not be turned on ...). Quote Link to comment Share on other sites More sharing options...
tractorboi711 Posted May 17, 2014 Author Share Posted May 17, 2014 Ok thanks , what colour cable would I be looking for that comes out if the stock head unit ? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
