LewisJackson93 Posted May 18, 2014 Share Posted May 18, 2014 I have a ghia and the interior lights ain't working when I change them to a blue led bulb which is a w5w bulb, also the light in the back of the at ain't working what may the problem be? Please can someone help me Quote Link to comment Share on other sites More sharing options...
Nighthawk Posted May 18, 2014 Share Posted May 18, 2014 Try the bulb in the other way round as LEDs only work one way, also check the fuse if you haven't already. Sent from my HUAWEI Ascend P2 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
LewisJackson93 Posted May 18, 2014 Author Share Posted May 18, 2014 Where is he fuse for the back interior light? Just that I'm new to ford, I've tried putting the w5w blue les bulb in the footwell as well but nothing, I place the original bulb and works fine :/ Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 18, 2014 Share Posted May 18, 2014 LED Bulbs work one direction only, remove and rotate 180 degrees and put them back in, if the bulbs aren't defective then it should work and if the holder works as well too! Sent from my MY SAGA C2 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
