1989jeffrey1989 Posted May 18, 2014 Share Posted May 18, 2014 Hi, i got a mk1 focus that has a collapsed rubber pipe which goes into the back of the engine, i beleive its an oil breather pipe of some sort? Also been informed it is a common fault? Anyone know the true name of this pipe? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 18, 2014 Share Posted May 18, 2014 If you stick a photo up that will help? Sent from my MY SAGA C2 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
1989jeffrey1989 Posted May 19, 2014 Author Share Posted May 19, 2014 If you stick a photo up that will help? Sent from my MY SAGA C2 using Ford OC mobile app Hi jeebo, its the one with my thumb on top of? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 19, 2014 Share Posted May 19, 2014 I think that pipe is coolant related to the thermostat. It could be that there is a blockage in there, causing it to collapse. Get the engine hot and bothered, and then feel along that line, you might find that at some point it cools off and down to cool and comfortable? Quote Link to comment Share on other sites More sharing options...
1989jeffrey1989 Posted June 13, 2014 Author Share Posted June 13, 2014 Found the cause, its an emissions breather hose there £13 on eBay or £16 from a ford spares dralership, and an easy fix :) Quote Link to comment Share on other sites More sharing options...
