karlos1987
Rear Drum Brakes Seized.
This morning I went to move my car and as I took the handbrake off and went to pull away it felt as if the handbrake was still on.
I pulled away and there was a clunk now everything seems fine.
Will my brakes be ok? Or will I have to get the drums off and replace the shoes?
Sent from my C5303 using Ford OC mobile app
Mine's done this a few times. My previous Corsa did it too. Never been any other ongoing problems as a result.
Ok cheers.
Would it have anything to do with me cleaning my wheels yesterday do you think?
Could be. A little light corrosion sticking
Mine did it a few times and my corsa also did it too. Just drop the clutch and it goes bang and frees it up. To be honest it happens a little every time I have washed the car but sometime it seems the shoes have proper welded to the drum.
Sent from my Nexus 5 using Ford OC mobile app
The way the weather is now it's likely to be rust, either rain or condensation followed by hot and humid will seize it, I wouldn't worry about it.
Sent from my MY SAGA C2 using Ford OC mobile app
