AdBlock Warning
AJRTDDI
My Restoration Project / Build. (Mk4 Escort)
141 posts in this topic
Car before i started
post-48488-0-59510800-1400433525_thumb.j
i give car good clean and started to remove the 1.4 Carb Engine
post-48488-0-13668100-1400433572_thumb.j
Cutting out old battery tray for new panel to be welded and sealed
post-48488-0-51141800-1400433735_thumb.j
Changed the number plates to legal ones.
post-48488-0-63944400-1400433794_thumb.j
Test fitting the RS Archs and Skirts for cutting and ajustments for 5 door.
post-48488-0-46283800-1400433847_thumb.j
RS bonnet fitted
post-48488-0-81791900-1400434293_thumb.j
Front panel cleaned/rust proofed and primered
post-48488-0-84798600-1400434260_thumb.j
Starting to remove brake servo. (clutch/ Choke/Speedo cables ect)
post-48488-0-27428500-1400433915_thumb.j
removing carpets, sound padding ect.
post-48488-0-05469600-1400434182_thumb.j
have to grind down and repair few minor damage Update soon :)
then wiring and mechical parts to be removed (struts and springs arms and bushes ect)
chan1a, FiestaGirl89 and Lenny like this
Keep up the good work with it update me when you've finished ☺️
Thanks,
Lewis Watson-Thompson
Lenny likes this
will give car a good jetwash and engine degresser when the rest of the wiring loom is out.
i will rebuild the factory loom with new sleeving. Im not sure on color sceme yet! :)
idk what color to have the car painted yet.
Lenny likes this
Nice project mate, looking forward to seeing progress. :)
Lenny likes this
Looking good! Keep us updated with more pics :)
Lenny likes this
Looking forward to the polished result!
Lenny likes this
Sunroof and window screen removed
post-48488-0-04794900-1400600001_thumb.j
Lenny likes this
1.8 Zetec or 2.0 Zetec silvertop... mmmmmmmmmmm
Shall i go collect a ST170 and give it ago with megasquirt ? lol
Lenny likes this
build on hold till weather improves alittle :)
will update on new engine mounts to be made.
Lenny and FiestaGirl89 like this
Engine mount
You have to cut out the inner cam cover to hide the side engine bolt.
I will also add a peice of metel along the top of the mount to the rear to add strengh (3rd pic) (mod the the backplate may need to be trimmed for peice of mind)
Lenny likes this
Water pump and Alternator problems solved.
Use ST170 Tensioner.
Use CVH Alternator.
Use 950-1150mm 6pk Belt.
Lenny likes this
next todo. Grind and weld Inner seals and front member...
Then Rub down and prep the whole car.
Lenny likes this
Very nice mate.. for colour why not go with panther black/aubergine the same as a mk6 rs2000. Just a suggestion can't wait to see the finished project mate
Lenny likes this
s1 RS white i think im going todo.
Lenny likes this
brought Focus Flywheel didnt fit :( wasted 30 Quid.
Still looking for good welder.
Lenny likes this
How you getting on with the build?.....I'm at a stand still with mine, waiting to get it painted.
Sent from under the bonnet
Lenny likes this
It's abit slow found a lot of bodge work and was arrested and on bail. So yea a lot on my mind :(
Sent from my HTC One X using Ford OC mobile app
Lenny likes this
It will come together mate. :-)
Lenny likes this
I have cut and welded new wheel arch to find out I need new inner panel around fuel filler and new Jacking mounts and sills.
One rust job turns into 3 :(
Lenny likes this
I hope this don't get too above me.. losing my job and too much welding work means I may have to scrap it :(
Hope not mate, always people needing a good welder
Lenny likes this
