frostman83
59 Plate 1.6 Zetec Oil Change.
i have the filter and the oil.
what tools do i need to complete the job? i have a socket set but wondering if anything else will come in handy?
13mm socket and probably a oil filter wrench or screwdriver if your a bit of an animal
Sent from my GT-S6810P using Ford OC mobile app
Best to get a sump plug washer off ebay`, ford only seem to sell the washer with a new sump plug which is £5 or £6!
a can of wynnes engine flush costs under 10 pounds and is great for using before draining the old oil,
a can of wynnes engine flush costs under 10 pounds and is great for using before draining the old oil,WYN51265_zpsaaorlzvg.jpg
I would save the tenner and use it towards a good quality fully synthetic oil. Personally I can't see why modern engines using quality oil and serviced at the correct interval need flushing.
As Hyundai a said (in 2009 when they advised against the use of flushing products), an unusually dirty engine is not a normal problem.
Hyundai use solvent based glue to hold it all together thats there problem :lol: what about diesel engines with EGR valves in operation causing excessive carbon deposits to build up in the oil slowly leading to a blocked turbo oil feed pipe, :)
Ford have used an undersized oil feed, that's their problem :lol: I know of many diesels with hundreds of thousands of miles on the clock which have egr valves and have had nothing major done to them.
I have always been wary about engine flushes stripping out more than is good. My opinion is unless the engine needs a flush, leave it alone. Modern oils contain detergents so changed on time or before they should be doing the cleaning.
Did the oil change all was fine. The old oil was dark and had a strong petrol smell to it.
Thanks for all the help on here.
WHat do you guys recommend for spark plugs?
glad to here you did the change with success.... did you put a film of oil onto the rubber filter seal prior to fitting, if not dont worry...
i must be a animal then, as i must over tighten the filter due to every time i do a change its impossible to remove by hand lol
as i dont have a petrol i carnt help you, but ppl do upgrade the plugs for a better spark etc.... maybe a ngk iridium or something of its equivalent....
sorry i carnt help any further
Yes I put a seal on the filter. I removed the old one by hand.. It was tough mind. But all in all happy with my first attempt.
Have done spark plugs before but they will be next along with a pollen filter.
the 1 thing ive never done is my pollen filter..... ive read to many stories about them leaking once have been changed.... and tbf thats put me off.... lol
Isnt the pollen filter on the Focus behind the centre console as my CMAX was? (i.e. between the two footwells?) if so that shouldnt leak it was only the MK1 styling where the filter was under the windscreen that was the issue?
Well changed the filter. Was a bit tricky. Took around half an hour. Have to take glove box out and drop fuse box. Bit tight for space but no too bad all in all although the spark plug change was a lot quicker. All serviced for another year though so thanks for the input all.
