jgriff Posted May 23, 2014 Share Posted May 23, 2014 Im in search of some help from you lovely folk. Ive purchased a zetec s kit for my mk2.5 focus this week but need your help. The thing is, ive got a towbar on my car which i need every so often, so therefore the rear diffuser will need to be modified to accomodate it. I met with the man in the bodyshop today and hes a bit reluctant to go chopping it, so im wondering if anyone on here has a zetec s kit fitted with a towbar. If there is anyone on here that has this would you mind posting up a pic of yours on here to give me an idea of how much needs to be cut out. I generally remove the hitch from the car when its not in use, just for asthetic purposes and would like to be able to do so when the kit is fitted if possible. Thanks in advance John 1 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 25, 2014 Share Posted May 25, 2014 I havent heard of anyone doing this, but I have to be honest, and say - if you need a towbar, dont bother with the Zetec S kit at the same time. so if you want to put the towbar on, then remove the S kit, put the standard on with the towbar, then swap over when your done. Unless your looking to leave it permenantly? 1 Quote Link to comment Share on other sites More sharing options...
theduke Posted May 25, 2014 Share Posted May 25, 2014 theres a towbar kit available for zetec s 1 Quote Link to comment Share on other sites More sharing options...
salsheikh Posted May 25, 2014 Share Posted May 25, 2014 the other option you have john is to fit the zetec s add on trim to your bumper - look at post no 95 - yunii's car http://www.ffoc/forum/index.php?/topic/90476-focus-titanium-mk25-build-diary-has-started/page__st__80 1 Quote Link to comment Share on other sites More sharing options...
jgriff Posted May 25, 2014 Author Share Posted May 25, 2014 Cant get to see that link salsheikh for some reason, maybe my phone. Ive been searching the net for solutions and my only options are to either get rid of it altogether, or cut the diffuser which I dont want to do, or just change it for one that is detachable and designed to accommodate the zetec s kit without any butchery. When I detach the towbar then you won't be able to tell that there is one there at all 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted May 25, 2014 Share Posted May 25, 2014 Hi john, There was a guy perhaps still is on focusownersclub.com with a silver zetecS had a detachable towbar and no problem with the diffuser section, His signature picture was his focus parked infront of some blaxk&yellow flood gates Saw him on there for a long time so i assume hes easily found also see here: http://diy-towbars.co.uk/ford-focus-towtrust-detachable-towbar-2008-2011 Quote Link to comment Share on other sites More sharing options...
jgriff Posted May 25, 2014 Author Share Posted May 25, 2014 Yea thats the type of one I was lookin at lenny. The one I have at the moment, the bottom of the bumper had to have a 2" square cut out to accommodate it. Really dont want to cut the diffuser for something that isn't used too often 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted May 25, 2014 Share Posted May 25, 2014 Yea thats the type of one I was lookin at lenny. The one I have at the moment, the bottom of the bumper had to have a 2" square cut out to accommodate it. Really dont want to cut the diffuser for something that isn't used too oftengood thing is the zetecS kit will cover the cut out, Im sure you could remove the existing towbar kit, quick spray coat black and sell it onwards on perhaps Adverts.ie That would cover atleast have the cost of the detachable. 1 Quote Link to comment Share on other sites More sharing options...
jgriff Posted May 25, 2014 Author Share Posted May 25, 2014 Yea thats the plan anyway. Is there much hassle to removing the rear bumper in order to change the towbar Quote Link to comment Share on other sites More sharing options...
Lenny Posted May 25, 2014 Share Posted May 25, 2014 Yea thats the plan anyway. Is there much hassle to removing the rear bumper in order to change the towbarstraight forward removing mate, But plenty of WD40 on the side bolts, Remove some screws from the rear inner wheel arch and reach inside to remove the nut from a bolt on either side, Go easy though, because the head of the bolt is moulded inside the plastic bumper bracket and it the nut sticks, it can lock up resulting in ringing the bolt, Replacement brackets are cheap like 20 euro each but preferably not need them, Four bolts and two plastic rivets to remove the rear bumper 1 Quote Link to comment Share on other sites More sharing options...
jgriff Posted May 25, 2014 Author Share Posted May 25, 2014 Cheers Lenny, hopefully it won't be too much hassle 1 Quote Link to comment Share on other sites More sharing options...
