Heated Seats
martyn j
I have a mondeo st mk3 55 plate the passenger seat heats up but driver's side does not yet the button does work any one got any ideas much appreciated also mi ESP and ABS are not working ?
Sent from my HTC One using Ford OC mobile app
Certaibly worth checking the connectors under the seat first
It sounds more like a connector under the passenger footwell fusebox, if your ABS and ESP arent working.
Its possible they are two seperate issues, but start off by checking the basics with the connections.
Yes they are separate issues just want to know if anyone had same problem and how they fixed it
Well, I had this issue recently and although its gone away, the issue normally is the connector is loose and needs to be disconnected and reconnected, but the battery should be disconnected for 20 minutes first to make sure you dont trigger the airbag deployment.
The ABS and ESP fault may be as simple as a faulty short loom or wheel sensor, you need error codes to really identify exactly where the issue is. If you have the trip computer, turn the key to 0, press and hold reset, then turn the car over and let go of reset only when you see test on screen. press reset repeatedly to cycle the menus and you will get to DTC - is it none or are there any readings?
Dtc are none and I'll try unplugging and plugging back in
  • 3 weeks later...
highly unlikely, that is just a notifier, if they arent working it means that a common element they both use is not working. Perhaps either a bad ABS sensor, or a module, or a short loom for that matter!
