Rulip Posted June 2, 2014 Share Posted June 2, 2014 I have a 2013 Mondeo Estate which came fitted with SAT Nav but no instrructions. I have worked most of it out however I don't know how to increase the volume. Can anyone assist Quote Link to comment Share on other sites More sharing options...
ianincheshire Posted June 2, 2014 Share Posted June 2, 2014 Use the volume control WHEN the Sat Nav is saying something. That will adjust the sat nav volume only and it will remember the setting. Odd isn't it, you'd expect there to be an option somewhere in the menus to adjust sat nav volume but AFAIK there isn't! BTW you should be able to download the SatNav manual from here http://www.ford.co.uk/OwnerServices/Owners-Manual?selectedYear=2013&selectedModel=Mondeo+-+A2 Quote Link to comment Share on other sites More sharing options...
Italiot Posted June 4, 2014 Share Posted June 4, 2014 I have the dvd 7 inch screen model and the volume can be adjusted as stated above while nav is speaking or go into menu Volume settings Nav button will not be lit so press the audio button on settings screen will will enable nav button so you will be able to set perfect volume without rushing Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
