P0301 Cylinder 1 Misfire
71 replies to this topic
#16 stef123
stef123
  • Management
  • 5,866 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 04 June 2014 - 09:09 PM
Hope it's not a burnt valve.. An injector would be a better answer. You can pick up a set of them cheap enough
Have something to contribute?
#17 nazsky786
nazsky786
  • True Ford Enthusiast
  • 590 posts
  • Name: Naz
  • Ford Model: FOCUS MK2
  • Year: 2005
Posted 05 June 2014 - 06:19 PM
Ok ignition system working all good, fuel injectors work all good. All that left is compression and most likely I will have a prob there.
#18 stef123
stef123
  • Management
  • 5,866 posts
  • Name: Stefan
  • Year: 2006
Posted 05 June 2014 - 07:11 PM
Sorry if I've missed it, you have checked that cylinder 1 spark plug is sparking?
#19 nazsky786
nazsky786
  • 590 posts
  • Name: Naz
  • Year: 2005
Posted 05 June 2014 - 07:35 PM
Yh is sparks. I lifted it a bit to hear and you can hear it. But sound weaker then the other 3 but the ht lead I tested works and so does the coil pack.
#20 nazsky786
nazsky786
  • 590 posts
  • Name: Naz
  • Year: 2005
Posted 06 June 2014 - 04:14 PM
Ok cylinder 1 has failed the compression test only having 50 compared to 120 on the other 3. So we are talking a big problem .
#21 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • PipPipPipPipPip
  • 1,731 posts
  • Name: Kurt
  • Ford Model: Focus Zetec S
Posted 06 June 2014 - 08:05 PM
Oh boy that is a big problem
#22 nazsky786
nazsky786
  • 590 posts
  • Name: Naz
  • Year: 2005
Posted 06 June 2014 - 08:16 PM
I know. No I have to track down why it's losing compression.
#23 stef123
stef123
  • Management
  • 5,866 posts
  • Name: Stefan
  • Year: 2006
Posted 07 June 2014 - 01:45 PM
Have you got a compression tester now? Put a bit oil in and try again, any improvement will indicate rings. If there is no change, it's probably a valve.
#24 nazsky786
nazsky786
  • 590 posts
  • Name: Naz
  • Year: 2005
Posted 07 June 2014 - 01:46 PM
Ok. I tried it dry.
#25 stef123
stef123
  • Management
  • 5,866 posts
  • Name: Stefan
  • Year: 2006
Posted 07 June 2014 - 01:49 PM
Oo err haha
#26 nazsky786
nazsky786
  • 590 posts
  • Name: Naz
  • Year: 2005
Posted 07 June 2014 - 01:52 PM
That's just wrong. How much oil should I put in the cylinder?
#27 stef123
stef123
  • Management
  • 5,866 posts
  • Name: Stefan
  • Year: 2006
Posted 07 June 2014 - 02:17 PM
One or two tablespoons of oil will be fine.
#28 nazsky786
nazsky786
  • 590 posts
  • Name: Naz
  • Year: 2005
Posted 07 June 2014 - 03:43 PM
Piston rings
#29 nazsky786
nazsky786
  • 590 posts
  • Name: Naz
  • Year: 2005
Posted 07 June 2014 - 03:45 PM
With oil they all go to 120 psi.
#30 artscot79
artscot79
  • PipPipPipPipPip
  • 7,995 posts
  • Name: arthur
  • Year: 2006
Posted 07 June 2014 - 04:10 PM
Sounds like it needs a new piston ring ide just do all of them at once though
Not what you're looking for?
