gav007
2007 1.8 Tdci Ghia
Not exactly the greatest first post made by a new member!
So why do you not like the MK2, many people enjoy it, and the MK1 was revolutionary at the time, the MK2 is still a very good car!
I got about 130 miles for £20 of diesel in MKI
Get about 110 miles for £20 in MKII
Its noisier (no soundproofing)
sounds like a transit van
My own fault for buying it without a test drive
Asumed it would be as good as MKI that i had for 10 years and loved it
I can see why your not a fan on those scores, but could the fuel price be a factor on the miles? less fuel for your £20?
As for the soundproofing, it makes sense, it is a bit louder as there is less soundproofing inch for inch, but that can be relatively easily resolved.
depending on the engines health it could be as much the reason for soundling like a diesel, you can blank the EGR and do a service that will help reduce the knocking.
Did you buy from a garage / trader or a private sale?
I bought it from Arnold Clark 1.8 TDCI Ghia
forgot to say the sony cd player is not as good as
the Ford 6000 cd on my mki
Forgot to mention when i put the foot down you hear
a rush of air in cabin as if the blower motor is on
(This is with the blower motor off ) any ideas ?
look for a split in the intercooler hose.
It's the large pipe that sits just under the engine cover on the drivers side of the engine bay.
Take the car back and in writing also, confirm what the complaints are with the car. The whoosh noise is likely a split hose or pipe. The diesel knocking could be a dodgy EGR or injector.
You can get the car improved by getting the garage to acknowledge there responsibilities in the sale.
You were spot on mate split hose cheers
No worries.
The symptoms you described were a dead giveaway.
I had it on mine, started as a whistle and ended up as a full blown roar followed by a warning light once the turbo pressure built up to boost.
If you want it, I have a useable hose that might be of use to you.
Thanks for the offer mate but got one of fleebay for a £10
Anyone used an EGR cleaner is it any good
I remember changing the turbo and inlet manifold
of my mk1 focus and it was THICK with gunk hard to believe
a 150ml spray can could remove it ?
its easy to use, but not quite so recommended. if it breaks a small clump of carbon off, that can be enough to kill the turbo or worse still stuff the engine.
