Hornet boy Posted June 8, 2014 Share Posted June 8, 2014 After some quick advice please. My wife's car (2.0 TDCI 130 Euro 4) has thrown up fault code P0251. I want to check the EGR valve first, so have taken it off and cleaned it, but can anyone tell me exactly how to check it while iit is off? I don't have access to a vacuum pump, but can take it to my local garage during the week if a vacuum pump is the only way. I don't have access to another EGR eiither. Should it be possible to move the valve by hand? The car has got this type of EGR: Thanks all. Quote Link to comment Share on other sites More sharing options...
FOCA Posted June 8, 2014 Share Posted June 8, 2014 What year is your wifes car? - that does not look like a Euro 4 electronic EGR valve - if you could post a picture of the actual car/ valve that would help Just stick a solid EGR blanking plate on it - then there will be no need to test it (as a solid plate effectively disables the EGR valve) and this will save you a lot of money (Aout £5 for the plate and £125-190 each time you need a valve - some owners have got through 4 ) + not forgetting the plate allows the car to run smoother/ better with better pick-up from low revs, and often better economy, and once the plate is fitted the inlet ceases to be contaminated by carbon, and smoke from the exhaust is often reduced too Quote Link to comment Share on other sites More sharing options...
Hornet boy Posted June 8, 2014 Author Share Posted June 8, 2014 Thanks for the reply. I will post up a picture of the actual one shortly. Ford Etis shows it as 'Stage IV emissions', and the log book says Euro4, which is why I assumed that's what it is, but I know that these have both been known to be wrong in the past. Thinking that it is Euro 4 is what has stopped me considering the blanking plate because I know it can cause the EML light to come on and as it's my wife's car she would rather there were no lights showing. Quote Link to comment Share on other sites More sharing options...
FOCA Posted June 8, 2014 Share Posted June 8, 2014 What year is your wifes car? This is the Euro 4 valve - http://www.ebay.com/itm/Ford-Mondeo-MK3-2-2-EGR-Exhaust-Gas-Recirculation-Valve-OE-New-/151321762176?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AMondeo&hash=item233b7ad980&vxp=mtr its a 2.2 but the 2.0 is the same, it has an electric motor in it, it is fitted to later Euro 4 cars with the electronic turbo actuator, the one you posted does not have a motor in it Many owners fit solid EGR blanking plates to their EURO4 cars, they either ignore the engine light, and/ or reset it with a code reader, they put up with this minor thing for all the advantages of having a solid plate fitted Quote Link to comment Share on other sites More sharing options...
Hornet boy Posted June 8, 2014 Author Share Posted June 8, 2014 Sorry, I forgot to say it's a 2004. These are pictures of her EGR & actuator: I have noticed that there is a lot of oil on the outside of the turbo (see last picture) which I'm guessing shouldn't be there, so perhaps I need to re focus my attention? Quote Link to comment Share on other sites More sharing options...
FOCA Posted June 8, 2014 Share Posted June 8, 2014 Thats interesting - you have the electronic actuator but not the EGR with the electric motor in it (that makes a multitude of different versions) - you should fit a solid blanking plate and see what happens I also recommend you clean out your inlet manifold as well the oil may just be from the crankcase breather/ a leaking hose What a horrible ugly thing that EGR valve is! - and look at the shape on the inside- with protrusions and voids in the gas flow Quote Link to comment Share on other sites More sharing options...
Hornet boy Posted June 8, 2014 Author Share Posted June 8, 2014 Thanks for all your advice. That'll be what's confusing me then if it's a combination of the two. I did clean take the inlet manifold off and clean it too. I will order a blanking plate and see how it goes. One last question, if I blank the EGR off it will take it out of the equation, and therefore if the car runs as normal after blanking we can be fairly sure that it was the EGR causing the problem? And if the car is still playing up I keep investigating! Quote Link to comment Share on other sites More sharing options...
FOCA Posted June 8, 2014 Share Posted June 8, 2014 Thanks for all your advice. That'll be what's confusing me then if it's a combination of the two. I did clean take the inlet manifold off and clean it too. I will order a blanking plate and see how it goes. One last question, if I blank the EGR off it will take it out of the equation, and therefore if the car runs as normal after blanking we can be fairly sure that it was the EGR causing the problem? And if the car is still playing up I keep investigating! No problem! P0251 = injection pump fuel metering control A malfunction 1st thing to do is fit a new fuel filter ("quality" brand or genuine Ford "cheap" ones can cause problems ) Still worth fitting the solid blanking plate, though IMO A non-blanked EGR valve does cause problems - even when its working "correctly". problems include, flat spots, hesitation, lag at low revs, poor performance at some revs, poor economy & further problems caused by the carbon/ gunge building up in the inlet (manifold/ EGR etc) Quote Link to comment Share on other sites More sharing options...
