Willy Posted June 8, 2014 Share Posted June 8, 2014 Is it possible to reset the ECU by pulling a fuse instead of disconnecting the battery? I know this is possible on the mk2.5 Focus (KAM fuse) I'm trying out some different fuel hence the ECU reset Quote Link to comment Share on other sites More sharing options...
Willy Posted June 8, 2014 Author Share Posted June 8, 2014 Any technical guru's out there ;) Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted June 8, 2014 Share Posted June 8, 2014 If it works disconnecting the battery then why not do it that way ? :p no radio codes anyways ? Quote Link to comment Share on other sites More sharing options...
Willy Posted June 8, 2014 Author Share Posted June 8, 2014 All the hassle of setting up my favourite audio levels ;) 1 Quote Link to comment Share on other sites More sharing options...
mixmasterlooney Posted June 8, 2014 Share Posted June 8, 2014 The ecu isn't the only controller of the engine although it is the main but what about all the other sensors? They would not have been reset? Control models for sensors etc? Sent from my GT-I9300 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 9, 2014 Share Posted June 9, 2014 I agree, I dont believe you would get the same effect. All the other modules (BCM, CCM, ABS, ESP, SRS etc) will still have information and it wont give you a "clean start". Quote Link to comment Share on other sites More sharing options...
Willy Posted June 9, 2014 Author Share Posted June 9, 2014 So no KAM fuse in the Fiesta. battery disconnect it is then. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 9, 2014 Share Posted June 9, 2014 Its easier anyway :D Who wants to go digging for one fuse in a big pile, when you can just pull a big off cable :p Quote Link to comment Share on other sites More sharing options...
