Strange Fusion Problem, Help Needed!!!
Function ford
33 replies to this topic
#31 INDUSTRYHATER
INDUSTRYHATER
    Member
  • Members via FB
  • PipPip
  • 16 posts
  • Name: aaron
  • Ford Model: Ford Fusion plus
  • Year: 2004
Posted 16 June 2014 - 05:08 PM
UPDATE
So today I took the car back to the guy who flushed the system for me, he thinks the thermostat is faulty and there is no circulation.
I had also booked the car into a ford specialist. The specialists also thinks it could be the thermostat, he's going to strip it down on Thursday and check all the surrounding pipes. He is confident coolant is getting through the radiator ok. There's also the possibility that a Ecu could have a fault as well but for now he's thinking the thermostat could be partially open or even installed the wrong way.
He said he took the car for a spin and the the dash showed it overheated but he checked the engine and he said it was fine. He also said there is no gases in the coolant. It's due to go back on Thursday.
In the meantime the missus is going to take the car to the original garage who did the thermostat to bollock them and see what they say ( remember these are the guys that said a slipping clutch was causing the problem, £460 later it wasn't) if it turns out they changed the thermostat housing and not stat and charged me for them both, they come together, then we'll be asking for money back.
I'll keep this thread updated just in case anybody else ever has problems similar mine.
Thanks for all your hell so far, it's much appreciated,
Aaron
Have something to contribute?
#32 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,492 posts
  • Name: James
  • Year: 2007
Posted 16 June 2014 - 07:30 PM
Good luck Aaron, I wouldnt definately give them a kick for it!!!
#33 INDUSTRYHATER
INDUSTRYHATER
    Member
  • Members via FB
  • PipPip
  • 16 posts
  • Name: aaron
  • Year: 2004
Posted 18 June 2014 - 07:31 PM
hallelujah, the car is finally fixed.
The car went back to the garage today and it was confirmed the new thermostat had failed. Apparently it wasn't opening quick enough.
The garage put a new thermostat and housing on free or charge, No more overheating thankfully.
I can hear a slight whine when the car accelerates and slows down in low gears but I think that's unrelated.
Many thanks to all of you for your help.
Aaron
#34 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,492 posts
  • Name: James
  • Year: 2007
Posted 19 June 2014 - 11:35 AM
Result!
as for the whine, thats something I have noticed on auto's most of them are like that!
Not what you're looking for?
Also tagged with one or more of these keywords: Function, ford
