Gasket Cover Advice
4 replies to this topic
#1 saklak
saklak
    Member
  • Budding Enthusiast
  • PipPip
  • 29 posts
  • Name: Marius
  • Ford Model: Focus MK2 Ti-VCT
  • Year: 2005
Posted 11 June 2014 - 04:37 PM
I'm planning to replace the gasket cover because this one leaks. Wondering if doing it outside it's ok, I'm thinking to wind + dust... I'm not leaving in desert but still,
I don't have an inside place.
I've been quoted by ford for £70 which seams to me huge and local garage I don't trust, they all hurry and I want to do it right.
I also heard that replacing this does not fix it, or it fixes it for a period. Any advice here ? The cam cover should be cleaned in any way, using a degreaser or something ?
Thanks alot for any advice.
Have something to contribute?
#2 dezwez
dezwez
    Dezwez
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 5,385 posts
  • Name: Derek
  • Ford Model: ford focus 1.8 zetec mk 2.5
Posted 11 June 2014 - 05:05 PM
wait till you have a sunny day no wind and clean it well.
I used some instant gasket sealer on mine I got new rubber gasket form local auto parts shop
sealed it well :)
#3 stef123
stef123
  • Management
  • 5,871 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 11 June 2014 - 07:14 PM
Clean the cover with some degreaser before you remove it, wipe away any loose deposits etc. remove the cover and gasket - check the cover is not warped.
Clean it up with a little degreaser and make sure the mating face on the cylinder head is clean.
Fit your new gasket - shouldn't be any need for instan gasket. Tighten the bolts up in the correct order to specified torque.
#4 saklak
saklak
    Member
  • PipPip
  • 29 posts
  • Name: Marius
  • Year: 2005
Posted 12 June 2014 - 10:48 AM
Well i dont have a torque wrench and it seams expensive and l'm going to borrow one from somewhere if i can find otherwise I'll use a normal one.
I found the values it's 10Nm for cover bolts and 25Nm and 75' angle. Can someone confirm this values. Also I cant find the right order. Middle ones first and then the other ones ?
Thanks for the help.
#5 saklak
saklak
    Member
  • PipPip
  • 29 posts
  • Name: Marius
  • Year: 2005
Posted 05 July 2014 - 02:17 PM
Here's the order if anyone needs it.
I successfully replaced the gasket today. Everything seams fine now.
Not what you're looking for?
