1.8 Tdci Engine Failure Amber Light
37 replies to this topic
#16 Italiot
Italiot
  • Budding Enthusiast
  • 282 posts
  • Name: Aaron
  • Ford Model: Mondeo titanium x 2.0 tdci 140bhp
  • Year: 2009
Posted 19 June 2014 - 07:03 PM
I will try again loads of guides for mk3. But none for mk4 it's like people are afraid to touch them
Have something to contribute?
#17 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,965 posts
  • Name: James
  • Year: 2007
Posted 19 June 2014 - 07:47 PM
Its easy enough mate, if your blocking it off anyway, worst case scenario you may buckle or damage the pipe a little (seems highly unlikely) but if its not to be used, theres no harm.
I found the harder part was thinking I had broke it and trying to get it back in there again! I was bending it back into place with one hand, wrestling it and putting the bolt back in trying to turn it to get them back in place.
#18 Italiot
Italiot
  • 282 posts
  • Name: Aaron
  • Year: 2009
Posted 20 June 2014 - 09:48 PM
I have a 2.0 tdci is that the correct route or Is it different as I know the 1.8 is compleatly different
#19 Italiot
Italiot
  • 282 posts
  • Name: Aaron
  • Year: 2009
Posted 20 June 2014 - 09:54 PM
Can you advise the best way to remove the clip from the pipe from the egr to inlet manifold
Manifold end
#20 Italiot
Italiot
  • 282 posts
  • Name: Aaron
  • Year: 2009
Posted 20 June 2014 - 09:56 PM
#21 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,965 posts
  • Name: James
  • Year: 2007
Posted 21 June 2014 - 03:09 PM
You shouldn't need to remove the clip, just undo the bolts, but the 2.0 is electronically operated so may result in the eml
Sent from my MY SAGA C2 using Ford OC mobile app
#22 Italiot
Italiot
  • 282 posts
  • Name: Aaron
  • Year: 2009
Posted 21 June 2014 - 08:51 PM
I have had the egr unbolted bit it felt like it was stuck on
#23 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,965 posts
  • Name: James
  • Year: 2007
Posted 22 June 2014 - 06:02 PM
It does you need to be firm to move it
#24 pauld2411
pauld2411
    Member
  • Members via FB
  • PipPip
  • 14 posts
  • Name: Paul
  • Year: 2009
Posted 14 July 2014 - 05:00 PM
Ok , so I bought the blanking plate as recommended , everything for the last month has been ok but I haven't done any motorway driving so lower speeds , I thought the hesitation had disappeared until today when the car started its "jerkiness" at approx. 45mph to rectify I slowed down and the problem disappeared again , could this still be an EGR sticking or could there be a split in a hose somewhere , there is slight black soot deposits on the side of the EGR where the inlet hose connects to it , this is fitted tight , there are also amounts of black smoke on heavy acceleration but not any other time , is this an air intake problem rather than EGR ?
#25 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,965 posts
  • Name: James
  • Year: 2007
Posted 14 July 2014 - 07:57 PM
It's quite likely to be a split if that's the case
#26 Italiot
Italiot
  • 282 posts
  • Name: Aaron
  • Year: 2009
Posted 14 July 2014 - 08:01 PM
When I tried to be form to remove egr the car just went up and down
#27 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,965 posts
  • Name: James
  • Year: 2007
Posted 14 July 2014 - 08:08 PM
Not sure I know what you mean?
#28 Italiot
Italiot
  • 282 posts
  • Name: Aaron
  • Year: 2009
Posted 14 July 2014 - 08:12 PM
I had two hands on the egr and was just shaking the car
#29 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,965 posts
  • Name: James
  • Year: 2007
Posted 14 July 2014 - 08:20 PM
Did you undo the two bolts?
#30 Italiot
Italiot
  • 282 posts
  • Name: Aaron
  • Year: 2009
Posted 14 July 2014 - 08:23 PM
I've tried the two on each end and the two on the egr
I've tried using Haynes manual but doesn't really explain how to remove there's not online guides for mk4 to be honest there isn't many mk4 guides online for anything
Not what you're looking for?
