1.8 Tdci Engine Failure Amber Light
37 replies to this topic
#31 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,328 posts
  • Name: James
  • Year: 2007
Posted 14 July 2014 - 08:56 PM
basically the centre of the engine where the pipe comes off, thats the EGR you need to disconnect the pipe off, remove the two bolts from it, then firmly pull the pipe back away from the head then refit the pipe with the plate on it as well.
Have something to contribute?
#32 Italiot
Italiot
  • Budding Enthusiast
  • 275 posts
  • Name: Aaron
  • Ford Model: Mondeo titanium x 2.0 tdci 140bhp
  • Year: 2009
Posted 15 July 2014 - 01:05 AM
Will have to try again maybe on the weekend
#33 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,328 posts
  • Name: James
  • Year: 2007
Posted 15 July 2014 - 09:17 AM
to be honest, thinking of how mine looks and yours, the biggest issue you face is the fact that as you pull the pipe away it will by its nature move less in direction that the pipe leads. By this I mean if you just undo the bolts and then push the pipe back, it will have a wider gap at the side of the front of the engine, and the one at the rear will have less of a gap. Either way, if you undo the nuts to the point they are being held on by about 2 or 3 threads then try to pull the pipe back, you should open enough space to then slot the plate in, relocate the pipe and bolt it up,
#34 Italiot
Italiot
  • 275 posts
  • Name: Aaron
  • Year: 2009
Posted 15 July 2014 - 04:34 PM
Mines a 2.0 which I thought were in different location. Mine feels like its welded
[ImageUploadedByFord OC1405441432.364610.jpg attachment=17910:ImageUploadedByFord OC1405441410.996269.jpg]
#35 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,328 posts
  • Name: James
  • Year: 2007
Posted 15 July 2014 - 07:38 PM
Your egr appears to be above the dipstick, Is this what your working on?
Sent from my MY SAGA C2 using Ford OC mobile app
#36 Italiot
Italiot
  • 275 posts
  • Name: Aaron
  • Year: 2009
Posted 16 July 2014 - 09:56 AM
Yes the pipe runs to there but the valve is at the other end at the back which is what I can't get off
#37 Italiot
Italiot
  • 275 posts
  • Name: Aaron
  • Year: 2009
Posted 16 July 2014 - 09:57 AM
#38 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,328 posts
  • Name: James
  • Year: 2007
Posted 16 July 2014 - 10:56 AM
When your working at the back of the engine,. and you undo the two bolts, is there like a T piece where another hose comes out of the EGR pipe just behind the bolts? if so you might need to follow both pipes and undo the support brackets further down the line. I had this on my CMAX when I did it, like you it didnt move and this was the reason.
Not what you're looking for?
