RooBaby
Remote Central Locking - Streetka
Hi all! Just a quick question about the remote central locking on a 2005 StreetKa
It had been awhile since I drove the car so it required a jump start. Since then, every time I unlock the car via the fob, the alarm goes off. It's only a short burst and then switches off. Is this a sign that something isn't right? I.e the battery in the fob is low, or the main battery is low in power and requires replacing?
I've not had to manually open the doors which is what I found my last issue was with the alarm so I know it's not that. Each time I open the doors the alarm goes off longer than the previous time.
What's causing this to happen?
Hope you can help. :) x
Sounds like you have water ingress somewhere in the system.
Best thing to do is to to check the fuseboard, fusebox in the engine bay and make sure theres no signs of water ingress. It sounds like the central locking is shorting out the alarm system causing it to blip
Stupid question, but is the boot shut? This causes the hazard lights to have a fit if it's not shut correctly.
Yeah... Boot is shut.
Cool I'll check the fuse box to see if there's an issue there.
I'm needing the car tomorrow so shall see what it does when I unlock it. Grrr all I've had is problems since I bought the thing :(
Sadly Roo it sounds like you and I share the same luck in motors, lol.
I am beginning to hope that my misfortunes are passing though, and if my luch can turn (bang head against wood) perhaps yours may too!
I hope so! I still have my classic mini to get running too! That is electrical and am not looking forward to locating the fault :(
Alarm on Cosmos (my streetka) had a blip this morning and has behaved the rest of the day. I've had the hood down twice. May have possibly been the hood compartment not being closed properly causing the issue?
I will know for certain when I come to use it again.
