AdBlock Warning
mitsi
99 Ford Ka 1.3 Starting Problem,
15 posts in this topic
Hi, I have a problem getting my ka to start, its been sat there for a year whilst ive been kearning to drive, ive had a new battery, oil and filters changed, spark plugs are good, getting a good spark, its got fresh fuel in, ive just used easy start and got it started but it wont rev up very much and themn just cuts out. Any ideas on what the problem could be.
Oh and thanks for any help in advance.
did you have the fuel filter changed as well?
It sounds like its an idle control valve issue to me?
how would I find out if its this?
ive got a fuel filter just got to get my brother to change it for me.
You said you changed oil and filters but sad this oil filter only or fuel as well. The fuel would gunge up and likely block the filter up
Sent from my MY SAGA C2 using Ford OC mobile app
fuel filter has now been changed as well, still wouldnt start,
Was the battery kept charged through the storage period?
Have you also cleaned the Idle Control Valve?
No old battery was shot, ive replaced this with a new one, am getting more new spark plugs tomorrow as my brotger says two arent sparking as well as the others, whereabouts is tge idle control valve?
Not sure on the ka I'm afraid have you got a Haynes manual?
Does it start any better if you give it some throttle while turning it over?
nno it will fire up if I use easy start on it, but it wont rev, have checked accelerater cable thats fine.
Ive been told its either the inertia switch or the fuel pump, ive found the inertia switch, is the button supposed to be down or up?
The button should be down, if its up its been disturbed somehow (ie accident, kerbing or similar jolt).
Thanks, ive got a new fuel pump now just got to get it fitted
Before you go wasting time changing the fuel pump, can you hear the pump priming when you turn the ignition on?
