howey90
Limp Mode
Hi all i have a 1.6 petrol mk1 focus elle and to day out the blue went in limp mode turnd it of was ok then back in about 3 time i came straight home plugged it in and only code was 02 sensor (after cat) so i cleared it and its ok for now any of you guys ever herd of a o2 sensor causing this course i haven't got me puzzled ?
Limp home mode is usually only activated in turbo powered diesel and petrol cars with over boost problems to prevent damage to the engine. A lambda sensor normally just triggers a emission fault as the ecu can no longer check the exhaust gasses but not cause any drivability issues. A voltage spike could be a likely cause
