AdBlock Warning
Stu1983
Mk3 Zetec Estate Rear Wheel Issue
4 posts in this topic
Hi Guys,
For a while now, I've heard some odd noises from the O/S/R Wheel.
Started as a faint 'whoosh' noise but on longer journeys (and more recently) it's more of a squeak or squeal. It stops if I brake and isn't always constant. Seems to do it more when stopping or pulling away.
I jacked up the Car this afternoon to have a quick look around (I'm no mechanic but thought I'd might be able to clock something).
When I jacked the offending side of the Car up, I had the handbrake on and I could spin the wheel around and around easily.
I jacked up the other side, handbrake on and couldn't move the wheel at all.
Any ideas what this is? Guessing, from the fact I can spin the wheel it's handbrake related?
Cheers.
Sounds like the cable could have snapped or you have a cylinder issue but the brake should work on booth sides when applied.
I couldn't take the wheel off today, couldn't find the sodding locking wheel nut.
I've read that the cable can seize etc... so I am hoping a liberal squirt of WD40 may free it up again (if it is that).
If not, it's back down the garage for the 2nd time in 2 weeks :-(
If it's not coming on at all it could have snapped but let's just hope some WD40 does the job.
