Headlight lamp is getting full of condisation don't know where water is getting in
Hi Kieron,
Its probably the seals, you need to remove the headlight and make sure that the cluster cover at the back is securely on.
Ok if it's the seals can they be fixed if so how or do you have to get a new one thanks??
Hi Kieran,Y
ou should be able to buy them from Ford relatively inexpensively if they are the fault.
