Towbar Wiring On Focus 1.6 Tdci Zetec 2010 #help
13 replies to this topic
#1 leofynn
leofynn
    Member
  • Budding Enthusiast
  • PipPip
  • 10 posts
  • Name: Adam
  • Ford Model: Focus 1.6 tdci zetec
Posted 02 July 2014 - 03:41 PM
hi. ford focus 1.6 tdci zetec. have fitted fixed flange towbar with single electrics. i have ran my 12v feed from the battery to the boot. I have located the plug in wire socket in the nearside boot side.. however
I am now unsure which colour cable goes to which bulb?? I' am sorry if this has already been posted. I am new to this forum. Any help really appreciated
Adam..
Have something to contribute?
#2 Gabbo_21
Gabbo_21
  • Members via FB
  • 183 posts
  • Name: Chris
  • Ford Model: Focus Sport TDCI
  • Year: 2011
Posted 02 July 2014 - 08:17 PM
Adam,
This is a job I need to do after fitting towbar, so will let you know if I get to it before you
#3 leofynn
leofynn
    Member
  • PipPip
  • 10 posts
  • Name: Adam
Posted 03 July 2014 - 04:33 AM
Brilliant, thanks. Glad it's not just me:) I've been told to trace them with a multi metre, was just hoping that I can save some time if someone has maybe already done it. Fingers crossed.
#4 Lenny
    Retired Moderator
  • 11,399 posts
Posted 03 July 2014 - 04:49 AM
Adam,
Hi guys,
I have the Haynes manual for the focus, ill post the loom colour reference at some point today before 22:00 im in work at present but ill post on this thread,
Also no need to run a 12v feed from battery because the focus already has a 12v positive in the boot see here: http://www.fordowner...oot-focus-mk25/
#5 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,133 posts
  • Name: Clive
  • Year: 2015
Posted 03 July 2014 - 12:55 PM
I have a PDF manual here if it's of any use-
https://www.dropbox.... PDF Manual.pdf
Sent from my S5
#6 Lenny
    Retired Moderator
  • 11,399 posts
Posted 03 July 2014 - 03:48 PM
Firstly guys if you have a diesel model i highly recommend you blank your EGR Valve, if you have a 1.6TDCi see guide here:
http://www.fordowner...-16tdci-engine/
Thanks to Clive linking the Haynes PDF there saves me going through a list, see page 12.28 of Haynes for "Typical Trailer Socket" diagram
Id like to link a few guides of mine to aid the end results,
Here's a link to the 12V socket guide which shows the factory fitted 12v supply in the drivers side of the boot,
Next i would like to link my guide to fitting dual reverse, in this guide you will see how the boot floor grommets can be removed and opened to allow additional cables be put through the factory hole:
http://www.fordowner...25/#entry158997
And finally this link to installing an additional boot light shows how to remove panels in order to access wiring looms from either tail lights.
http://www.fordowner...083#entry146083
If your in need of some automotive electrical cable or connectors i highly recommend logging on to AutoStar a uk based supplier Dave is top man, unbeatable quality aswell as combined postage on group purchases,
And if like me: you ndvdr know "what AMP of cable should i be using for...."
Dave is happy to advise if you tell him your plans,
Here's a link: http://stores.ebay.co.uk/autostarshop/
Although the manual displays the Mk2 on the cover, it refers to the Mk2.5 aswell on the inside:
#7 leofynn
leofynn
    Member
  • PipPip
  • 10 posts
  • Name: Adam
Posted 03 July 2014 - 06:13 PM
Thank you Clive and Lenny.  This is really useful im sure all the info i need is here now and nearly making sense too! :) just not that switched on with electrics. can you tell me which part of the diagram is the plug in the boot? ill post a pic of mine.
sorry if im being thick!
 adam.
#8 leofynn
leofynn
    Member
  • PipPip
  • 10 posts
  • Name: Adam
Posted 03 July 2014 - 06:20 PM
#9 Lenny
    Retired Moderator
  • 11,399 posts
Posted 03 July 2014 - 06:35 PM
 adam.
Id say item number 44 there is the loom socket in the boot because its feeding to the various signal feeds already,
So all you need to do is pair up your trailer loom pins with the cables on your plug there.
Wire the socket to correspond with the plug on the trailor.
Dont plug in the loom until you have completed socket first because it will blow fuses if shorted.
#10 leofynn
leofynn
    Member
  • PipPip
  • 10 posts
  • Name: Adam
Posted 03 July 2014 - 06:49 PM
Thats what i was thinking too, its just for example. LH rear indicator says grey and white cable but i dont have a grey and white cable on my loom socket :s
if the colours matched up to the haynes diagram it would be plain sailing :)
Thanks for the other links too Lenny very useful!
#11 leofynn
leofynn
    Member
  • PipPip
  • 10 posts
  • Name: Adam
Posted 05 July 2014 - 09:16 PM
All i can think is that maybe i need the 05 11 focus manual as this suggests the wiring is different to the 09 focus.
#12 Gabbo_21
Gabbo_21
  • Members via FB
  • 183 posts
  • Name: Chris
  • Year: 2011
Posted 10 July 2014 - 06:39 PM
You need this loom for passenger side
Blue - indicator
Green/Red - Brake
Orange/white - tail
#13 leofynn
leofynn
    Member
  • PipPip
  • 10 posts
  • Name: Adam
Posted 10 July 2014 - 07:28 PM
Wow thank you so much. That's just what I needed!! That's matches my cables and makes so much sense at last!! Is that all I need that side do I need to run any to the OSfir anything? Thanks again. Massive weight off my mind
#14 Gabbo_21
Gabbo_21
  • Members via FB
  • 183 posts
  • Name: Chris
  • Year: 2011
Posted 10 July 2014 - 07:39 PM
You have
Blue/red - right indicator
Orange - right tail
You then have fog light through the grommet on drivers side
Not what you're looking for?
