Mk1 1.8Tdci Starting Problems
6 replies to this topic
#1 creation
creation
    Newbie
  • Budding Enthusiast
  • Pip
  • 3 posts
  • Name: Martyn
  • Ford Model: MK1 1.8 TDCI
  • Year: 2002
Posted 02 July 2014 - 08:55 PM
I have got an intermittent starting problem with my car. Sometimes when I turn the key the solenoid will engage on the starter but the engine doesn't turn over. Usually when this happens it doesn't matter how many times I turn the key the car won't start, however sometimes after 10 or so attempts the car will decide to start, if it doesn't I have to bump start it.
When my car does start it starts fine. I can go days and it will be fine and some days it will fail to start multiple times. The stater motor is less that 6 months old, I fitted it myself. I have double checked all the connections on the starter and the battery earth and they are fine. When the car fails to start if I put the lights on they don't dim.
When this first happened the car did this for about 3 weeks then the problem just went away for a couple of months, but it has now returned. It will happen when the engine is cold or warm.
Any ideas what could be causing this, I don't want to have to ask for more bump starts at the petrol station!
Have something to contribute?
#2 vinnyvangough
vinnyvangough
  • 2,325 posts
  • Name: Steve
  • Ford Model: 2003 Focus TDCi, Escort Mk6 RS2000, Mk2
  • Year: 2003
Posted 02 July 2014 - 09:44 PM
Possibly teeth missing off the flywheel or starter gear?
#3 creation
creation
    Newbie
  • Pip
  • 3 posts
  • Name: Martyn
  • Year: 2002
Posted 03 July 2014 - 07:51 AM
The flywheel was replaced this year and I have had the starter motor apart and I can't see any teeth missing.
#4 mjt
mjt
  • True Ford Enthusiast
  • 515 posts
  • Name: Mike
  • Ford Model: Focus Mk2.5 Zetec 1.8HE
Posted 03 July 2014 - 09:12 AM
That clearly shows there is no power going to the starter. Although you said it's only 6 months old this does sound like a starter problem. If you're hearing a definite click from the solenoid then either the contacts are not feeding power to the motor or there is a problem, such as a sticking brush, in the motor.
#5 IINexusII
IINexusII
  • 825 posts
  • Name: James
  • Ford Model: Focus 1.8 TDCI Zetec Climate
  • Year: 2006
Posted 03 July 2014 - 09:52 AM
get a stick and tap the starter while someone is cranking the engine. if it cranks then you know its a bad starter. if it doesnt still start then its probably a wiring issue.
#6 creation
creation
    Newbie
  • Pip
  • 3 posts
  • Name: Martyn
  • Year: 2002
Posted 03 July 2014 - 11:36 AM
That
Well it was only a cheap starter from ebay. I guess I should get a multimeter and test the connections on the starter?
I have tried that, sometime it does start when doing that and other times it doesn't, which  I know isn't much help!
#7 mjt
mjt
  • 515 posts
  • Name: Mike
Posted 03 July 2014 - 03:51 PM
You could use a meter to check the voltage is reaching the solenoid and doesn't collapse when you operate it but if the fault is inside the solenoid or motor using a meter won't help.
Not what you're looking for?
