matchador Posted July 3, 2014 Share Posted July 3, 2014 Hi everyone i am new here and i have a serious problem with my focus 2005 1.6 tdci engine. i have a major leak on top of my engine.it appears to be oil but i am not sure.i changed the injectors seals twice but the problem still exists i changed the the top cam cover seal also.so now what should i search next?i am desperate cause i went to many different garages and noone seems to can find the problem.also is it normal to have oil in the pipe that goes from the engine back to the intake pipe? Quote Link to comment Share on other sites More sharing options...
IINexusII Posted July 3, 2014 Share Posted July 3, 2014 that looks more like water/fuel than oil to me from those pictures. oil will be black/brown and look much thicker Quote Link to comment Share on other sites More sharing options...
matchador Posted July 3, 2014 Author Share Posted July 3, 2014 That's why I washed the engine and and then I drove about 1000 meters but the engine was not 100% dry and that's the outcome.the strange thing is that it comes out from the hole of the injector although I have new One rings.so maybe my injector is cracked somewhere?how can I check it? 1 Quote Link to comment Share on other sites More sharing options...
matchador Posted July 3, 2014 Author Share Posted July 3, 2014 That's because I washed the engine and and then I drove about 1000 meters but the engine was not 100% dry and that's the outcome.the strange thing is that it comes out from the hole of the injector although I have new O rings.so maybe my injector is cracked somewhere?how can I check it?the fluid that comes out its black and doesn't smell thats why I supposed it is oil. 1 Quote Link to comment Share on other sites More sharing options...
Buding Wen Posted August 9, 2014 Share Posted August 9, 2014 That's because I washed the engine and and then I drove about 1000 meters but the engine was not 100% dry and that's the outcome.the strange thing is that it comes out from the hole of the injector although I have new O rings.so maybe my injector is cracked somewhere?how can I check it?the fluid that comes out its black and doesn't smell thats why I supposed it is oil. Totally same problem. Do you have any clue now? I heard there is major problem from Injector # 3, which will result in destroying the Turbo and finally the engine must be changed. I am not sure if this is symptom of that disaster. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 10, 2014 Share Posted August 10, 2014 A common fault with the 1.6TDCi is leaking injectors, Early diagnosis is king, Refurbished injectors available on eBay but require ford diagnostic software to get them working on your engine, They need to be programmed to your specific ecu, So ford only job, Ive not yet read the thread content here just te title but thats im input on the subject 1 Quote Link to comment Share on other sites More sharing options...
matchador Posted August 10, 2014 Author Share Posted August 10, 2014 i tried everything and searched everything.in the end i changed these 2 screws and problem is fixed .i should have thought that from the beggining....hope that helps others too. 1 Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted August 10, 2014 Share Posted August 10, 2014 just a quickie on the injectors, cant they be reprogramed with the modified ODB2 adaptor rather than go to ford? 1 Quote Link to comment Share on other sites More sharing options...
