adam_pryor
2006 Ford Fiesta Freedom Trip Reset
9 posts in this topic
Anyone know why my trip reset on my 2006 ford fiesta freedom isnt working?
The reset switch is on the indicator stalk, if i take the fuse out and replace it the button works once, then nothing???
(it is Not the fuse problem)
Can anyone either link me to a repair or tell me how to repair it please?
have you tired removing the battery for an hour letting everything die out, then put it back on and restart everything ?
Yea ive tried that
Sent from my SM-N9005 using Ford OC mobile app
My next step is taking the stalk apart (which i want to avoid)
it could be the stalk on the circuit board not making a connection if its that the speedo unit is pretty easy to take apart and check, you could solder it back together but if not you could it to ford
Ok, thanks ill give taking the stalk apart and checking the board inside a go, if not i can replace the stalk? Is ebay a good shot for that part?
um in not sure you could try and repair the stalk you have if not probs pennies from ford anyway
Ok, thanks for the help, ill try to find out how to take them apart and post on here when its sorted :)
My button also died - I replaced the stalk with one I got for a few quid on ebay.
