Broken Bluetooth Module
Robpd
Hi there,
The bluetooth and aux in my fiesta doesn't work, which i'm fairly sure is down to a faulty bluetooth module. The one I have at present is an 8A5T-19G488-AL.
Would I be able to just plug in an 8M5T-19G488-AJ to fix the problem?
http://www.ebay.co.u...=item338d7a02ca
Also, what would the costs be to add USB?
Cheers
  • 4 weeks later...
The module 8M5T-19G488-AJ is noted down in the ford ecat as:
From: 21-07-2008 To: 02-10-2008 Fiesta 2008-, BT/VC Phone Interface Only,
Voice Activated Module - British
If you could send me your reg then I may be able to help further.
Regards Rob
Yes it would be fine. For USB as well you'd need a different module, wiring loom, fascia trim for below the gear stick & silver trim+rubber cap for USB port. The ECU then needs reprogramming by a Ford techie.
