Clutch Fluid Leaking On Drive.
7 replies to this topic
#1 josh7195
josh7195
    Member
  • Budding Enthusiast
  • PipPip
  • 21 posts
  • Name: josh
  • Ford Model: focus 1.8 tdci 3 door hatch
Posted 09 July 2014 - 07:04 PM
Hydraulic clutch fluid leaking under car on to drive way, have to keep toppiing up resevoir every couple of days when computer sends me an alert and harder to get in gear.
Have something to contribute?
#2 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 8,006 posts
  • Name: arthur
  • Year: 2006
Posted 09 July 2014 - 07:39 PM
sounds like the clutch slave cyliner has gone if you look at the bottom of the gearbox bell housing is it wet with oil if so the slaves gone so a new clutch and slave cylinder will be needed
#3 josh7195
josh7195
    Member
  • PipPip
  • 21 posts
  • Name: josh
Posted 09 July 2014 - 08:06 PM
Sounds about right do you think im going to be paying about £900 ?
#4 IINexusII
IINexusII
  • 824 posts
  • Name: James
  • Ford Model: Focus 1.8 TDCI Zetec Climate
  • Year: 2006
Posted 09 July 2014 - 09:14 PM
what mileage is your car? youll probably also need to replace the dual mass flywheel. all in (with DMF) it shouldnt cost more than around 600.
#5 josh7195
josh7195
    Member
  • PipPip
  • 21 posts
  • Name: josh
Posted 10 July 2014 - 06:42 AM
About 55.000 sounds reasonable I supose
#6 josh7195
josh7195
    Member
  • PipPip
  • 21 posts
  • Name: josh
Posted 10 July 2014 - 06:13 PM
Do you think 55.000 is way to soon for anything like that to happen?
#7 IINexusII
IINexusII
  • 824 posts
  • Name: James
  • Year: 2006
Posted 10 July 2014 - 06:33 PM
depends on how you drive. bad clutch use will give issues like this very early
#8 artscot79
artscot79
  • PipPipPipPipPip
  • 8,006 posts
  • Name: arthur
  • Year: 2006
Posted 10 July 2014 - 07:41 PM
It can happen anytime really its likely a rubber seal on the slave cylinder it will eventaully go altogether so youll have no gears as happened to me no warning no slip it just went
Not what you're looking for?
