AdBlock Warning
ss03947
Ford 6000 Rds Eon
8 posts in this topic
Hi, First post & a question for the experts.
I have a Ford 6000 RDS EON cd/radio that I want to fit in my caravan, bought one off ebay, arrived today, but I'm having problems getting it to work.
I've connected it to a 12v battery/speakers, & on switching it on I'm asked to enter the code, which I do, the radio then displays this in the picture below.
Pressing any button after this is futile, it still displays the same no matter what you press, & the CD Player doesn't work.
I also need advice on this aswell. Correct me if I'm wrong, do I just need a positive, & negative + speaker connections to make this work in my caravan.?
The picture below shows the connections on the back of the CD/Radio.
On connector A I have number 1 connected to the positive on the battery.
Connector A I've number 6 to the negative.
And I'm using 5,6,7,& 8 on connector B for the speakers.
Have I got this wired correctly.?
Or do I need further connections.?
Also I see that the ariel is a differnt fitting, can I get a proper fitting, or do I need to solder the connections.?
Sorry for the questions, but I'm not really upto speed on this stuff.
Thanks in advance,
SS.
Tbh it sounds like a duff radio if the buttons aren't changing anything.
It could be as simple as dirt/crud on the button contacts, maybe a quick clean?
Going further you may have a damaged/yanked ribbon connector between the panel and radio body.
Does the cd not auto start when a disc is entered or will the isc not even load in?
Wiring you've indicated looks fine to me.
As for the aerial connector, you will most likely need a din to iso adaptor.
Sent from my S5
Thanks for the reply.
No, it doesn't auto start, wont load.
Cheers,
SS.
It does sound like a damaged ribbon connector or duff buttons then.
TBH I'd send it back as U/S on receipt.
They are pretty common on ebay so another one will be inexpensive to source.
Yep, been in touch with the seller, it's getting picked up Tuesday.
Thanks for the help.. :D
SS.
