mighty_kong
Cylinder Misfires
I'm not sure whether the bluefin remap or something else may be at fault?
Anyone know the cause and remedy of cylinder misfires. See below torque logs:
Fault log report generated by Torque for Android =================================================
Vehicle VIN: WF0EXXGXXXXXXXXX
Vehicle Manufacturer: Ford
Vehicle Calibration ID: BG91-14C204-LH
Current Fault Log
P0351: Ignition Coil "A" Primary/Secondary Circuit
P0300: Random/Multiple Cylinder Misfire Detected
P0301: Cylinder 1 Misfire Detected
Pending Fault Log
P0302: Cylinder 2 Misfire Detected
P0304: Cylinder 4 Misfire Detected
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
End of report.
Sounds like a faulty ignition coil. Its likely the cause of the misfires that are being recorded separately.
I took the remap off and went back to defaults. The problem has gone away and the engine fault light. This is the second bluefin remap that has gone wonky on me. They seem stable for a month then everything goes '!Removed! oop'?
