footfistart Posted July 19, 2014 Share Posted July 19, 2014 So I've fitted the ignition illumination and it doesn't work. I've unplugged it and plugged in the original light and it doesn't work? I've checked the fuse 104 in passenger fuse box and it's fine? Any other reason or another fuse? I need help ASAP? Many Thanks Ryan Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted July 19, 2014 Share Posted July 19, 2014 Have you looked at lenny guide on this? Sent from my C5303 using Ford OC mobile app 1 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted July 19, 2014 Share Posted July 19, 2014 So youve disconnected the light and put the light plugs into the ring plugs then plugged the other 2 ring plugs into the light? If youve done that and the fuse is okay the rings faulty Theres 4 plugs on the ring 2 where the interior light plugs into and 2 that go on the interior light connections Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 19, 2014 Share Posted July 19, 2014 Check fuse 104 again, sometimes they blow without any visual clues. Ford cars are very sensitive to the courtesy lamps being worked on. The fuse should be 10A. Guide to double check your connections too- Fitting footwell lights to your car Modified.pdf Quote Link to comment Share on other sites More sharing options...
footfistart Posted July 19, 2014 Author Share Posted July 19, 2014 It lives. The fuse did blow just didn't look like itI pulled it out and was fine and a few others just incase but they were all fine. So I locked the car and went back and had another check at that fuse with fresh eyes and it was blown. Your right the car is sensitive. It's done and works. The wiring is horrendous. On one of the plug is had to take the connectors of and crimp them myself as one wire had cone away from feeding in the roof liner. I followed the guide to a tee. It looks good I'll gets pics. I just need some 501 leds to match the colour now. I went for white light as I can't stand coloured light in cars. Thanks for all your help all the same. Ryan Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 19, 2014 Share Posted July 19, 2014 Glad you got it sorted out. Yeh, the courtesy light is very hard on fuses for some strange reason. When I swapped bulbs in my light when I first got my car I blew 3 fuses in quick succession. Tbh I pulled the wrong fuse and put it back in the wrong slot, just my luck it was for the immobiliser. Much cursing and sweating insued. Sent from my S5 Quote Link to comment Share on other sites More sharing options...
footfistart Posted July 20, 2014 Author Share Posted July 20, 2014 Three fuses?? Doh! I'm glad I had a couple of spare crimps laying around and the right size. Wouldn't be able to do that again. I didn't enjoy this mod only because of the trim. It's a pain to remove and refit. A lot of it removed a refitted a couple of time to realign bits. But done now. What fuses did it blow as I'll be replacing my bulbs to match the ignition just so I know if it happens to me. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted July 20, 2014 Share Posted July 20, 2014 Have you looked at lenny guide on this? Sent from my C5303 using Ford OC mobile app :) thanks karl, Heres a link for those on Google: http://www.fordownersclub.com/forums/topic/34704-guide-fitting-footwell-lighting-to-your-ford/page__fromsearch__1 Quote Link to comment Share on other sites More sharing options...
