Mk3 Towbar Electrics, Converter Needed?
jimbro
 Share
Someone just told me I may need a converter to wire in my towbar electrics.
Something to do with the "intelligent" lights
Any ideas about this?
Think they're talking about a multiplex
Link to comment
Believe it may be Canbus he was talking about
Does the MK3(2006 Ghia) have it?
I just went out, disconnected the rear cluster and put the ignition on:===no warnings about lights
Does this mean I don't have it?
Link to comment
Jim I always fit a bypass relay, for a few reasons. Firstly it means whatever your towing is not putting any extra load on any lighting circuits but most importantly it means you have the buzzer that is required to be fitted.
You could also fit a lamp on the dash if you wanted instead of a buzzer but you need one of them. I find fitting the relays the best option for little extra cost. They are very simple to wire up and the mondeo also has a 15A supply already in the boot to power it.
Link to comment
Is the bypass relay for the 2nd socket? I'm only fitting a single skt to start with.
Sent from my HTC One using Ford OC mobile app
Link to comment
PS where is the 15a supply in the boot. That would make wiring twin electrics much easier
Link to comment
No the bypass relay is for your single electrics - your indicators, brakes lights etc
It lurking behind one of the carpets, on the passenger side iirc. It has a connector on it though so you will need to chop it off. You will also need to fit a fuse to make it live. I can't remember which fuse it is though
For the twin electrics where you can charge the caravan battery you will need a split charging system.. A little more complicated than single electrics
Link to comment
Ok thanks. So it already has a bypass fitted? In the boot? Sorry for the basic questions but these cars are new to me
Link to comment
No, if you want one you will need to fit one.
Link to comment
Great. Thanks for the help mate.
Link to comment
OK, bruv in law's bringing a bypass relay with him tomorrow.
Towbar arrived today
Just can't find the 15amp plug
Had all the carpets in the boot up and folded the seats down but I can't find it :(
Link to comment
If I get the chance I will have a look and take a picture for you
Link to comment
Here you go, behind passenger side carpet
For whatever reason the forum has rotated them..
post-3200-0-82078400-1406140380_thumb.jp
post-3200-0-36716100-1406140396_thumb.jp
Link to comment
OK, I'm officially thick
Where is this picture? I can't identify it
Link to comment
It's behind the carpet in the boot on the passenger side. I just lifted it from underneath
Link to comment
Rotate those pics 180 degrees, they should make sense then
Link to comment
OK, here's my boot with the wheel well cover lifted and the side matting removed
Could mine be different? No voltage on either the blue/green or the black. Did check fuses and both trailer ones are missing
Link to comment
Rotated them and I see where it should be but I don't seem to have it
Link to comment
OK, got some 30A cable and a splashproof inline fuseholder so I'll just run it from the battery to the boot.
Already a good earth there
Thanks for the help again :)
Link to comment
Hmm strange, I thought all mk3s had a 15A supply.
30A cable is a bit over kill but you shouldnt see much of a volt drop anyway lol.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
