ChrisF94 Posted July 26, 2014 Share Posted July 26, 2014 Hi, My MK1 focus takes about 5 seconds to start, I've Put new Ignition leads in, New spark plugs & Coil pack I don't know what it could be. I Changed the battery about 3 months ago. Sometimes when I have my lights on they go dim for a second when I'm driving. Thanks for any help. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 28, 2014 Share Posted July 28, 2014 its highly likely that this will be the cause of your issue. If the car cannot breathe then it cannot start, or will struggle. The car will try tuirning over, until it builds enough exhaust pressure to the point that it has enough energy to burst through the CAT and breathe, thats when it starts. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted July 28, 2014 Share Posted July 28, 2014 As above if the cats clogged youll have issues if it isnt already itll start running badly the dimming lights could be the wrong type of battery depends what you have fitted? Quote Link to comment Share on other sites More sharing options...
ChrisF94 Posted August 24, 2014 Author Share Posted August 24, 2014 bump Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted August 24, 2014 Share Posted August 24, 2014 Chris, Arthur and I both replied to you have you explored these avenues! Quote Link to comment Share on other sites More sharing options...
ChrisF94 Posted August 24, 2014 Author Share Posted August 24, 2014 Chris, Arthur and I both replied to you have you explored these avenues! I've had a brand new CAT fitted and a coil pack but still the same issue. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted August 24, 2014 Share Posted August 24, 2014 That's helpful to know always best to share that information lol. So new cat new plugs, did you change the ht leads also? Did you check your battery is indeed silver calcium, it should be on the battery itself Quote Link to comment Share on other sites More sharing options...
ChrisF94 Posted August 24, 2014 Author Share Posted August 24, 2014 That's helpful to know always best to share that information lol. So new cat new plugs, did you change the ht leads also? Did you check your battery is indeed silver calcium, it should be on the battery itself I changed the ht leads and my battery is Quote Link to comment Share on other sites More sharing options...
stef123 Posted August 24, 2014 Share Posted August 24, 2014 Does the car have any performance or running issues? Quote Link to comment Share on other sites More sharing options...
ChrisF94 Posted August 24, 2014 Author Share Posted August 24, 2014 Does the car have any performance or running issues? If runs fine when it's warm, It idles at 1500 when I first start it, Then goes down as it warms up. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted August 24, 2014 Share Posted August 24, 2014 Batteries should be silver calcium not lithium calcium so this won't be helping. I think you will have an idle control valve which will likely need cleaning so I would start by removing and cleaning it. I don't believe you have the mass air flow sensor but if you do It would need cleaning with electrical contact cleaner. Quote Link to comment Share on other sites More sharing options...
